MT-07 emergency lights issue
JacobSCroydon
This post is 2217 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi All,
I have an issue with emergency lights on my MT-07. Few weeks ago I replaced rear indicators with LED versions and did the same with front ones over the weekend. They work fine when indicating left or right, all blink once or twice when I arm or disarm the alarm, but when I try emergency lights they only blink once and stop.
Any ideas?
Thanks,
Jacob
Hi Jacob, you need a resistor in the power line to the indicator relay as the LED lights don't draw enough wattage to make the indicator blink. Look up "LED indicator resistor" on google and see what comes up.  follow this link http://www.ebay.co.uk/gds/Load-resistors-for-LED-indicator-bulb-replacement-/10000000010344226/g.html
Also say Hello in the new members section it helps if your not a one hit wonder. Just sayin..!
