Painting
Perryh16@googlemail.com
This post is 2252 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Nope, its powder coat. Chances are its laid on a base coat and that bstd reacts. Least it has done with the 2 bikes i have stripped and re done.
You ideally need to baremetal the sw arm and work up. Will give a finish worth the effort though.
Nope, its bolted in the same as any other swing arm with a spindle.
As above really, you have to be able to unbolt it if for nothing else than to grease the bearings. Usually every 6 to10 thousand miles.
Diagram of generic bearing showing the various bolts and shafts that need to come off. This one starts at number7. NOT your bike but similar I bet.
Image result for yamaha 125 swing arm
