DT 125
Khayledoe
This post is 2266 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Be honest.
When was the last time you or somebody :
New plug
New filter
Decoked the pipe (can off and shoved a hosepipe up the pipe, dry of course).
Time since last rebuild.
Any of these will affect the way the engine runs and ultimately the amount of smoke. A long run (20-30) miles with the bike held at 8500-9000 rpm even if you need to do it in 5th,   but better with wider throttle will burn a lot of the softer gunk right out. May smoke quite badly if you do get the gunk to light off. If you do keep going till it stops. Looks dramatic (especially at night as you get loads of red embers/sparks) but its not hurting.
Now get yourself into the new members area and say hi, this is a first post question :eusa_snooty:  or i may well be the only response.
