Seat/steering Locks
Jazza
This post is 2481 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hello All.
I have an 1976 RS 125.
Both the steering and seat locks are damaged, but I have the original Key.
If I get replacement locks, is it possible to remove the original lock barrels and replace these with the new locks so I can keep the original lock and not end up with two or three different keys.
I have stripped the original seat lock down, but cannot work out how to remove the barrel.
How do you remove the original barrel?
Thanks.
This tells you how to get the keyway out of the ignition block to help with the broken steering lock, you buy a replacement keyway and refit it to the original lock.
