600 s diversion 2003 brake light
Jim Murray
This post is 2527 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
You have obviously fitted it wrong..! Take it off, make sure it's still working ok, then try again. It's a micro switch with a very sensitive plunger if it's not straight or to far into the hole it will light off all the time.
Yes take it off and with it in your hand, connect the wires to it and test it. Once confirmed re-fit it carefully
Sent from my SM-G930F using Tapatalk
