Hi all, my 1st ask for advice, registered November
Quint1975
This post is 2537 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi there,
I have a 2009 YBR 125 Custom. and had no bother all winter, got to work early morning yesterday, then tried to start bike to go home, and it's not priming, lights come on, engine light, then goes off but no noise, press the starter,it tries but no banana!
Had to bus it went in this morning, tried it, it made the priming noise, and started! But tried later to go home, no noise, no start! Doh!
As you can tell I know nothing, have Google problem, and some say it could be the fuel pump, and also it being warmer weather!!
Anyway I use my bike every day, and would really appreciate some advise, if any one could, many thanks in advance
Paul
Sent from my D6603 using Tapatalk
Checked the battery recently, bet its either buggered outright or low on charge. Could be a charging issue but unlikely.
what priming mean? is the sound that come from fuel pump when she pump fuel when you put the contact?
if yes, may be the relay, a bad contact on fuel fuse or wires. check the contacts for fuel system first then if you can, try another fuel relay. anyway, sound like an electrical problem, don`t think is the pump.
