mikes xs petcocks
Brandonk24
This post is 2573 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
just don't forget to switch them off
use the bungs to plug the vacuum barbs where the lines fit over, they are the same used to plug the other vacuum barbs (what you use to balance the carbs)
i installed the petcocks but now the bike wont start. any ideas? ive been looking up info trying to figure out why, it was running but now it wont after the installation. and what happens if you forget to turn them off?
the fuel still flows and if your carb float needle is faulty, it could flood your engine and lock up the pistons.
you'll smell fuel if you you take out a spark plug.
