internal wiring through frame
dan28
This post is 2656 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
make sure the wires doen't get chafed and make sure they are wrapped.
each hole in frame should have grommets.
never done it myself but plenty on other forums like chopper underground
thanks I ll take a look on chopper underground
I found a few threads on the net from what I ve seen people file the hole an test it by pulling tissue through it when it doesn't tear the tissue its smooth enough obviously the wires are wrapped too
I ve not seen anyone use grommets
if you use grommets is it possible to get some that have a senseable external diameter I have some here that need a 17mm hole but the hole in the grommet is only about 10mm
On 05 January 2017 at 7:22 AM, drewpy said:
why not use a U channel trim, that should do it
thanks drewpy  that will work fine an will solve the problem of the wire coming through the grommet nearly horizontal I can use elongated holes with u channel trim an the wires will be vertical along the frame
