FZS 600 convert electronic speedo to mechanical (the solution)
ordni
This post is 2800 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi I am making some big changes on a 1990 fzs600 that has a electronic speed sensor and I was wondering if someone has found a mechanical speedo drive that fits to use with some vintage speedometers
Best regards Örn
why not use a GPS speedo, they are very accurate now.
Say hello in the new members section first too, we like to know peeps better :)
I am doing cafe look requested by the owner, and he wanted some specific speedo and tacho and the speedo is driven by cable so I need to find a mechanical speedo drive.
try an xj600 speedo drive, but it will need some machining on the wheel and lug on the fork to stop it spinning.
sure you can retrofit an old speedo with new internals
Does someone have the dimensions of a xj600 speedo drive, retainer clutch and driver washer?
I cant get any parts here in Iceland and its not fun ordering parts and have to wait 2 weeks to find out that I cant use them
  • 1 month later...
So if someone wants to know what speedo drive to use when converting to an mechanical speedo meter.
The answere is a speedo drive and cable from an Yamaha YZF 600 Thundercat.
Yamaha 341-25846-00-00 341-25846-00-00 RETAINER,CLUTCH
and Yamaha RD Speedometer Drive Washer, 341-25149-00-0
Its a perfect fit. just plug ad play.
20160726_105533
20160726_105538
20160726_105549
13892086_10153877202436872_4564358753100168470_n
20160726_111416
20160726_111406
20160725_162616
Have a Nice day.
looks great the speedo is the same as the FZ600 and probably most Yams from that period
