Dragstar brake lever too high.
jimmysheffield
This post is 2894 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Ok then, not sure what your skill level is so from the beginning. Take the brake lever off, after you have marked the lever and the shaft to show where it was, then rotate down wards till you have it in the place you feel comfortable then just run it back onto the splines of the shaft and do it up. But be aware that if you lower it to much then it can dig in the ground if you get to enthusiastic with it, you will have to adjust the brake pivot point as well to allow for the brake light switch. Should be fairly easy.
