My 1991 XJ600
Bigwol
This post is 3056 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Bought as a bike which wouldn't start in the wet, with no MOT in Nov 2014 - it's taken me almost exactly a year to work through the things that needed sorting - these included a fuel system clogged with jellied ethanol, a suspect TCI box (replaced with Ignitech unit), carbs that needed a thorough overhaul, exhaust fitting and stud problems, and a dragging clutch.
Jellied Carb Float Bowls
Main Jet needed a clean
Mikuni BS32 Carb jigsaw
You could eat your dinner off these now!
The end result
  • Like 3
Nice job mate, you must be well chuffed. These old bikes deserve to be looked after and they are fun  to ride.
Nice, I wish I still had mine.
49 minutes ago, drewpy said:
sweet, where did you get the ignitech from and how much?
Contact - Jiří Krejzl
Email At [email protected]
Website here - with all contact and product info.
http://www.ignitech.cz/en/
Their English is way better than my Czech,
Bought their ignition SPARKER TCIP4 - standard - plugs made for XJ600 1991 - including USB serial comms 9pin port and serial to USB adapter
It came to EUR 174, which at the time worked out to around GBP 130
True plug and play - and great service from ignitech
Give them my best regards if you talk to them!
Nice Work on the carbs!......:thumb:
Remember going through mine a few times on my old XJ....... Great Bikes!.......put over 130k miles on mine;)
I can't quite strip and rebuild them blindfolded -  but it's close.  And I even know where both the detent balls, and their teeny weeny springs go - (apart from under the fridge, that is)!
  • Like 2
