trodd69 Posted June 3, 2015 Share Posted June 3, 2015 Just thought I'd share some part numbers in-case it might help anyone who searches. I'm rebuilding some BS36 carbs off a friend's XJ900 (88) and am working in Spain. Getting any Yamaha parts has proven to be a nightmare but I eventually managed to track down what I needed from a Suzuki main dealer - it took loads of cross referencing and I wasn't sure what would turn up once the dealer got the part numbers in that I'd asked for (not speaking Spanish doesn't help!) however was pleasantly surprised tonight to go and pick up all the bits I was needing. So I got the butterfly shaft seals (8 pieces) - 13651-51010 idle screw O-rings - 13295-29900 A fuel gauze from on top of the float valve jet - 13376-19F00 A new rubber bung for covering the idle mixture screw - 13357-44080 and 1 x random tiny brass part with a little hole - 13281-05A00 (Google want's me to believe it's an alternator bearing but I don't!!) Probably not much use to most folk but hopefully the above can save someone in the future the few hours it took me to get the correct numbers. Of course note that these are SUZUKI part numbers - not Yamaha. Link to comment Share on other sites More sharing options...
