Yamaha DT125R poss electrical fault?
gaz-ando
This post is 3444 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi guys, any help would be appreciated!
I have a 2003 (53) model and when I turn ignition on I get nothing
Kick start and runs fine, no indicators until I throttle it. The back relay I think (white box by rear mid guard)
buzzes like mad until I throttle or touch either brake. I installed a brand new battery,
Turned ignition on and had 'N' come on ok, started fine. Then stalled when I put stand down
And now nothing when I turn ignition on and same scenario of starts fine etc. any ideas? Cheers
Hi and welcome! Was the battery fully charged?
You'll get a lot more help if you do a proper intro here (follow Airheads link above) and start a new thread in the workshop section.
:welcome:
sounds like batt, lights only running off alternator check the conections, the batt housing is right where your 2 part pipes meet, so gets gakky around there fast if no seal,
