Dt125 electrics cut and no spark
andyrach1979
This post is 3472 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
First you need is a wireing diagram,then main parts are pickup coil to cdi ,cdi to ignition coil and kill switch.
Then charging coil to regulator/rectifier to battery and ignition,lighting if you intend to wire it up as well.
The owner of the site has made it clear that no copy rights are to be broken so unless someone wants to sit and type out every wire for you,, doubt you going to get all that information. Hayans manuals are cheap and your local Yam dealer can do cd manuals or photo copy pages
PS you might be able to get the manual from your libary as well.
  • 3 weeks later...
if its been attempted to be derestricted they probbly used this method... http://www.scrimsmustangsclassicyamaharestorations.com/derestricting-the-yamaha-dt125r-1988-through-to-2007.html
when it comes to checking wires out, try reverse engineering this method see if somthing was changed wrong
it changes wires around arse about face ext, i beleive my bike to be done with these instructions aswell
