1970 DT1 C 250 Engine Rebuild
AWA
This post is 3585 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
As part of this restoration I decided to have the engine rebuilt. I took the engine to a small shop about a year ago. The mechanic had a multitude of personal problems and could not complete the job. I knew he had started to tear it apart so I went to recover it so I could complete the job. The engine was completely torn apart and the parts were in small unlabeled containers. So now I have all the parts and pieces and know idea of where to start.
The transmission seems to be intact. I have purchased all new bearings and seals. Piston and rings.
I have the parts manuals and the service manual but they don't thoroughly explain all you would need to know about rebuilding or the problems to avoid.
Any suggestions , special tools, or tips anyone could provide would be a great help. Also a good source for the less obvious parts such as shims and spacers would be helpful. I live in the Portland Ore. area. If you know a shop that would be willing to put this together, that would be nice. FYI, the bike is 100% restored other than the engine.Thank You for your help.
Hello welcome to the site.
A little introduction in the welcome section wouldn't go a miss.
Two stroke engines are incredibly simple to build. Try and guage it from the photos. And maybe put some photos up here for us to have a little mooch.
I do assume it's a two stroke
