Fairing repair
Adamjay90
This post is 3768 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Cant help you there, but you may be able to help yourself with this
http://www.classicbikeforum.co.uk/viewtopic.php?f=27&t=321
that's a good link.
have repaired plastics like that before. but I added some fibreglass I=on the inside as extra strength.
post some pics of your fairng for us to look at.
and it may be cheaper to get replacement panels rather than a pro repair....
  • 3 weeks later...
Nice link Jimmy been doing this for years but never thought to write it down (DOH!)
Yup, same thing I did...soldering iron and zip ties! I heard ABS pipe works well too...or you can also use acetone to melt the ABS together. Another tip is to fill a jar with some ABS pipe shavings and some acetone so it makes a runny paste and then put that in the crack after you notch it into a v-shape. I need to re-do some of my fix-up jobs though, didn't use enough heat to melt the zip ties, and then I made the mistake of using spot putty on the outside, which cracked.
