broken chain
This post is 3816 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
My chain broke this morning, a bit lucky I was only doing about 30 mph and chain wrapped around front sprocket. Anyway removed the demolished chain but found a nylon block inside the front sprocket cover. I am assuming it is probably a chain guide but where does it go or fit in the cover , it was just laying loose when I took it off and cant find anything in the workshop manual that helps.
probably on the end of the swing arm near the front sprocket
yes, thats my guess too, to keep the topchain run from dragging on the swingarm.I fyou look closely, you should see perhaps a couple om holes where it was screwed/rivetted on?
it may have been glued/stuck with mastic, so you may find a clean bit on the swing arm
