yamaha dtr wiring diagram needed?
Lewisarron0808
This post is 3958 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Thanks a lot mate really need that now time to sort the bike out lol
I have been told there is a wire in the speedo that if you earthed it your top end will be better dose anyone know what wire it is please has have no clue
Cheers
Behind your speedo they'll be a 4 pin plug, on the side coming from the loom, there should be 4 cables, one if which isn't connected to anything on the other plug.
I believe it's black with a green stripe running down it.
Earth that to the frame and you'll get the full rev range.
I.e.your powervalve won't shut off at 7000rpm.
