Why don't my DT 125R start in a few kicks?
BillyBennett
This post is 3958 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Try a new spark plug first and do a compression test.
Sorry Dirty Dt, didn't see the other categories
No problems Billy.
Do you leave your fuel tap on when parked?
Before you need to start it, take out the plug and describe the colour and dampness.
What happens if you try and start it with the fuel cap off?
What happens if you try and start it with the air filter off? - If it starts, turn it off as soon as possible. Don't let it run for too long
When was the last time the carb was cleaned out?
That should start you off. Let us know what happens on each.
I'm going to clean the carb, I've never cleaned it since I've had it so that might be the problem, I'll post the results when I've cleaned it, I'll get on it today! Thanks
