olney Posted May 7, 2013 Share Posted May 7, 2013 Do replicas (exhausts) exist for these yeasr or do you have to buy the original parts? Also, do older ybr engine parts fit the newer models? Any help very greatfully appreciated! Link to comment Share on other sites More sharing options...
Chazillor Posted May 8, 2013 Share Posted May 8, 2013 Firstly, I wouldn't bother with an aftermarket one because you will loose power where its a more free flowing system and the engine wont be set up for it. In terms of the ones for the older models they should fit, I know an '05/'06 pipe will go on the newer non facelift models so I assume they should work on newer ones. Problem with that is the '05/'06 pipes don't have the hose for the air recirculation I think, so you might have a problem with getting it MOT'd (although that's very unlikely) What is the problem, is the one you have broken? Link to comment Share on other sites More sharing options...
olney Posted May 12, 2013 Author Share Posted May 12, 2013 thanks very much for the reply, I havent broken one, I just want to get an idea of the cost of second hand parts as I'm looking to buy one. Do you know if engine and gearbox parts i.e. cylinder, head pistons etc..are the same on the 2010-13 facelift? I'm not anticipating any problems, but, just in case? Are the facelift bikes as reliable being made in china? Link to comment Share on other sites More sharing options...
