Racc Posted October 7, 2012 Share Posted October 7, 2012 Hi peeps trying to sort the Exup valve on my bike Doesn't do self test when ignition switched on, valve is free, if you pull the white and red bullet connection the servo moves and moves back when connected, all connections are clean, had it at one part when the servo was moving back and forth, but now nothing Help please Link to comment Share on other sites More sharing options...
barrybigbazneill Posted January 25, 2014 Share Posted January 25, 2014 It's fine it probably just done that cause it got a surge it should move when bike is running and if it ain't the servo is gubbed try other servo Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
