75 dt 250 enduro
This post is 4214 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hey guys i have 2 75 dt 250 enduros im going to make one good bike from the 2 and with my second motor it will be going in a golf cart witch is almost done. my question to you is what wires do i need to hook up to get it to spark. i need the harness for the other bike so i dont want to hack it all up. this bike does not run a battery. thanks,
I think you'll need most of the harness if you want to use a key. At least the wiring to and from the rotor, the cdi, rectifier, coil and main switch - or a kill switch if you want to set it up that way
Roger
here's a basic wiring component photo....
http://www.cmsnl.com/yamaha-dt250b-19751976_model8548/partslist/F-05.html#results
An intro would help no end. People dont generally reply to 1st post questions......
Drop into the new members area and say hi.
I thought these bikes used points.
Makes it a doddle to do.
Yip " Twinshock DT250"s are points, so too is the DT,MX,250f.[ early 1977] The DT400"s are cdi, ,
Welcome torence,, :jossun:
Just a suggestion as you have 1 harness make a copy of it.
I take it you need to make 1 for the golf cart.
So using a mulit meter set on ohms scale Identify each wire and simply make it longer.if you don't want the lighting/horn then omit them.
You will need the ignition coil, charing coil /points, voltage regulator, kill switch. Geting a wiring diagram will make this easier.
