vacum hoses on xvs 125
dan28
This post is 4235 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
were abouts do the vacum hoses connect on the carb on the xvs 125
i ve looked in the manual but it doesnt show them they dont appear to be connected on mine
The small hose in the middle of the photo is the one that comes from the carb and connects to the top of the air filter assembly. The connector pipe from the silencer is not shown in this pic but is an almost 90 degree bend that connects into the large hole of the assembly.
This is the back of the assembly with the air filter removed. The large hole takes the connection from the silencer. The small nipple above the large hole takes the tube from the carb seen in the other pic above.
The front of the assembly.
The removed air filter. Silencer connection in the middle which sticks through the large hole on the back of the assembly.
