RESET IGNITION TIMING
jimboz4
This post is 4421 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
HELP..!!!!!!!!!!!
Can anyone tell me the timing settings / procedure on my 2003 TDM 900 twin.......
P.S.
I am a member who hasnt been on for a while due to work commitments....
HELP
jimbo
According to the Genuine manual the ignition timing is not adjustable but you can check it. Remove the smaller inspection cover on the LH generator cover and conect a strobe light to number 1 spark plug lead i.e LH cylinder. Start and warm up engine for a few minutes and check idle speed is set at 1,100 - 1,200 RPM .Point strobe into inspection hole and check that the stationary mark set in the inside of the inspection hole is within the two lines on the moving generator rotor.
Tony
excellent, thank you tony...
