Bad vibrations
Alcorp
This post is 6934 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
My old XJ750 used to do the very same thing @ the same revs :huh:
I think I narrowed the culprit down to a camchain tensioner issue along with a need for a good carb balancing. :headscratch:
HTH
BTW...... :welcome: to the Forum ;)
all 4 cylinder bikes will vibrate at a certain revs,if the carbs are balanced it is better to adjust your speed to suit or alter the gearing
the old pre-exup engine is a bit more vibrating than the newer one... and still the t-ace owners keep saying that it vibrates. nothing really you can do to it. carb balancing as said before.
also a bit of help if you change the handlebar grips to "soft" ones. and add some massive antivibration endbars. no carbon here :D
