sisu Posted February 23, 2011 Share Posted February 23, 2011 Appreciating that there is a sticky topic on this I have a specific question re swapping out the headlight bulb and was looking for opinions and experiences (if any). It's 1 2010 YBR if that makes any difference. The bike is fitted as standard with a 35W/35W HS1 lamp. I spoke to a main dealer who supplied me a 55W/55W lamp saying that it should be ok but, maybe, there might be an issue with the battery being discharged if I spend a lot of time idling. Questions are: 1. Is there likely to be an issue with the supply wires? If my calcs are correct, a 35W lamp at 12V draws around 3 amps (35W divided by 12 volts) while a 55W would draw more like 4.5 amps [not sure if double filament wire on full beam has both on or if they alternate ... if both them amps would double for each case]. Anyone know what the rating is for the headlight supply wire or have a technical manual that they could look it up in? 2. Would the battery honestly be a problem? My (limited) understanding is that once started the alternator runs the electrics and charges the battery with any surplus - wouldn't I have to be starting and stopping the engine AND using all the juice to discharge the battery? I have seen quite a few posts of folks fitting additional lights (with a separate battery supply) so I can't see that the battery should be an issue. Anyone have any thoughts? Thanks Link to comment Share on other sites More sharing options...
X_FISH Posted February 24, 2011 Share Posted February 24, 2011 I have switched from the original romatic lighting ('05 YBR) to H4 like other owners in germany by changing the whole headlight. I am the only one (in the german ybr 125 bb), that changed the wiring as well. The others kept the original wiring - and everything worked well for over one year or more. The wiring and the switch seem to be able to handle the more amps well enough. About the alternator: I found a notice in a german bb that the alternator is large enough to have no problems with H4 55/60 or other bulbs with similar consumption. Some people have heated grips or use the bord system to load their navigation systems, mp3-players and cellphones while being on the road. I have switched the tail light from standard to LED - this also brought a small benefit of less power consumption. I have not experienced any problems with the battery while riding last year, the e-starter worked well all the time. In times of trouble my '05 also got the kick, but the '11 does not have a kick-starter any more? Greetings, Martin Link to comment Share on other sites More sharing options...
sisu Posted February 24, 2011 Author Share Posted February 24, 2011 Thanks Martin, great reply. Sounds like the wiring/switch should be ok so I will swap over the bulb and see how it goes. I hadn't thought about the load from heated grips etc so you are right, the lamp upgrade should be a minor issue in terms of the alternator's capacity. The 2010 does still have a kick start ... always nice to have a backup :-) I will post how I get on (probably be the weekend before I get it done!). Thanks again Link to comment Share on other sites More sharing options...
