stuart1507 Posted November 8, 2010 Share Posted November 8, 2010 Hi All, My 2002 FZS600 (foxeye)has started to get a small noise from the top end which i thought was the valves, I had a mechanic come and listen but he said it sounded like it was the cam chain and that i probable need a new tensioner. The bike has only done approx 27000 miles on a general 60 mile round commute, is this normal for the tension to need replacing at this milage and also when should i condider getting the cam chain changed. Finally does anyone know where i can get one from as other than yamaha? and is it a big job to change the tensioner? Cheers Stu Link to comment Share on other sites More sharing options...
Paulwhite Posted November 8, 2010 Share Posted November 8, 2010 as far as i know if the tensioner is as tight as it will go, and you get this problem ....you need a new cam chain! and try www.wemoto.com Link to comment Share on other sites More sharing options...
