squeaky rear brakes... :(
JohnnyK
This post is 4942 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi guys,
I've got the bike going into the shop on Friday for a good overhaul; getting some engine bars fitted, new chain/sprockets (front sprocket +2 teeth, as per MarkyBoy's experiment), got a new 100 jet, new brake lever, indicator stalk, oil filter, air filter, and a partridge in a pear tree...
Anyhoo, today driving into work I noticed the rear brake squeaking at low speeds when light pressure was applied... is this something sinister?
Cheers all John
Dirt ?
Dust?
Rust ?
It's only a 10 minute job to pull the pads out, give them a clean, a bit of copper grease and back to <non-squeeky> normal. Of, course that is, if you are happy, have the tools and the knowledge to do it.
Sounds like you've got a fair old list for the shop, just add to it!!
