74 DT175 carb float level height?
Stasch
This post is 4591 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I recently acquired a 74 DT175(A?).
I have a Clymer Manual which is maddenly evasive in stating the proper float level height for this carb.
The Float Level table in Clymer page 86 only shows info for these models:
GT Series, YZ80a, DT100A, MX100A, AT1 series (and MX), AT2, AT3, AT2-MX, ATMX, DT125A, MX125A, YZ100C, YZ125A, CT1 series, CT2, CT3, DT125A, MX175A
Is DT175A the correct designation for 1974 and could it be equivalent to AT2 or CT2 or CT3?
Thanks!
They all use a variation of the Mikuni VM24 carb, be it bigger or smaller, newer older and the float height is 21mm.
Bit more info,
DT175 A/B
Mikuni VM24ss
160 main,
5G4 jet needle
Clip 3rd groove from top
Pilot air screw 1 3/4 turns out
Float height 21mm +/- 1.0mm
Idle speed 1300-1400rpm
  • 11 months later...
Bit more info,
DT175 A/B
Mikuni VM24ss
160 main,
5G4 jet needle
Thanks Cynic. This post provided more answers than what you could have imagened.
