bigmandamo Posted June 13, 2010 Share Posted June 13, 2010 tdm 850 2000 model, taken all the gutts out from the fork,dust seal off clip out and tryed to draw hammer out the tube from the slider,can anyone advise please coz i need to change the oil seal and im struggling and need to get to work tomorrow Link to comment Share on other sites More sharing options...
Vez Posted June 13, 2010 Share Posted June 13, 2010 If you introduce yourself properly you will find people more likely to reply with help!!! Vez Link to comment Share on other sites More sharing options...
bigmandamo Posted June 13, 2010 Author Share Posted June 13, 2010 ok lets give it a go,hi my name is Damien and im new to this site im having problems splitting my forks can anyone help im getting stressed coz i need my bike for work and im shure ive done every thing rite like the book says but the tube and slider wount come apart to change the seal Link to comment Share on other sites More sharing options...
pilninggas Posted June 13, 2010 Share Posted June 13, 2010 like many yamahas, it probably needs you to use 'special damper tool' to undo the bolt that holds the caboodle together. I haven't done it for years, but you can hold it to undo the allen key underneath the fork using a piece of dowel (9mm or 12mm maybe) instead. It needs to be long enought hat you can tap it into place with a hammer. google around for a workshop manual, they are out there on the cyberweb Link to comment Share on other sites More sharing options...
bigmandamo Posted June 13, 2010 Author Share Posted June 13, 2010 ive taken the bolt out of the bottom if that is what you mean and still when i do the pull hammer affect they still dont come apart Link to comment Share on other sites More sharing options...
