aerox 50 loads of problems
muss93
This post is 5033 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hi there i have an aerox 50 and it jusr wont run properly its getting through a spark plug every 2-3 weeks and keeps breaking down on me it has had practically a full engine re-build and it still isn't running properly =/ i have been told a few things that it may be such as that the carb is set up wrong, the jet has worn out (so i've ordered a new one from my local yamaha specialist) or that the carb has done its time and now needs changing but i dont know what size carb it has. So does anybody have any usggestions on what the problems and solutions may be?
Hi muss and welcome
a bit sketchy on the detail there!
What do you mean
"its getting through a spark plug every 2-3 weeks and keeps breaking down on me "
What is happening to the plug, what does it look like when you take it out, have you checked its sparking, have you cleaned it and tried again, have you burned it over a gas hob?
is it breaking down because of your percieved spark plug issue?
Hi muss and welcome
What do you mean
after about 2 weeks it wont spark at all even if i clean it and warm it up and the plugs brown burnt and usually caked in road salt
If your plug is that bad why not buy a new one?
i do im having to buy a new plug every 2-3 weeks
  • 4 months later...
sounds to me like your fueling is rong and getting too much oil, normaly the jets are about 60 when they are standerd but with ware and tear they do need to be changed try a 63-64 or if you get a performance exhaust on they need upjeting by about 10 sepending on how good it is
