xvs 125 replacement fender options/ cable lengths
derbyshireyeomanry
This post is 5314 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi guys was wondering if anyone could give me some advice on whether or not one of those nice chromed front fenders off of an xs250 , rd250 etc would fit a 125 dragstar they seem to have the same 4 bolt hole fittings was just wondering if anyone had one they could measure up ,the dragstar fender is 12 cm across the gap and the bolt holes are 5cm apart on the mounting plate.
P.S Ive fitted some apehangers , and now throttle cable/clutch cable are pretty much at their limits anyone know of any longer cables maybe off of a xv 535 or maybe xvs650 would something like that fit ?
cheers for any advice
Cables you can have made to measure.
It's a bit more expensive, but very much worth it!!
Personally, I'd advise against customining a 125 as it affects the resale value if/when you move up to a bigger bike.
