fzrthow Posted August 24, 2009 Share Posted August 24, 2009 why does my 02 plate dt125 only do 70mph? Link to comment Share on other sites More sharing options...
peterxj600 Posted August 26, 2009 Share Posted August 26, 2009 70mph is about the top speed for a DT125. You could replace the rear sprocket with a smaller one (or the front with a larger one), that will give you a bit more top end, but you will lose some acceleration. P Link to comment Share on other sites More sharing options...
cranaj Posted August 26, 2009 Share Posted August 26, 2009 Maybe it's still restricted? Check out dtr125.net for info on making it faster. My 2007 DT did 65mph when it was all stock, then I earthed a wire behind the speedo and it rocketed (literally, in terms of performance gain) up to 76mph and that's 1 of the many restrictors! Removing them all and changing sprockets can result in daft top speeds of 100mph+ http://dtr125.net/tuningnewer.htm Link to comment Share on other sites More sharing options...
barwell1992 Posted August 26, 2009 Share Posted August 26, 2009 ^^ all of the above or you could just lose weight 1 Link to comment Share on other sites More sharing options...
forddude Posted September 5, 2009 Share Posted September 5, 2009 ^^ all of the above or you could just lose weight Ha Ha verey good mate, or a biger bike Link to comment Share on other sites More sharing options...
dt125 Posted October 11, 2009 Share Posted October 11, 2009 Ha Ha verey good mate, or a biger bike or8 matey it will only do bout 70 cus it will still be restricted ive got a dtr125 1999 model ile get about 125+ as ive had all ristrictors taken off ive had the head skimmed barrel ported to the max same as the head 34mm carb off a rgv wold flywheel lightend and my dads messed about with the crank to do with crank compression and ive got a tz125 piston init and it will rev out at about 1600 grand which is fuckin amazing is screams its bolxe off at u make sure u run it on good 2stroke castrol a747 spells gd and runs fuckin sweet as a nut but i prea mix it much better then u no u are defo gettin 2stroke through i all so have a tz125 pipe on it much betta i no it may not look as good coming under the bike but performance wise much betta than a arrow or a dep pipe there crap ive got both pipes and the rubbis to much of a swan kneck on them no good at all. the other thing ile be doing is putting a yz125 1992 hotrod crank in mine and putting a yz125 top end on brillant any questions just email me matey and ile speak to u about dt's matey sound luke Link to comment Share on other sites More sharing options...
scottcampbellridgway Posted October 3, 2011 Share Posted October 3, 2011 iv got a dt125 x 2007 and all its had done is the wire behind the clocks and a arrow exhaust and it will do 100 and everything else is totally standard Link to comment Share on other sites More sharing options...
NEV Posted October 3, 2011 Share Posted October 3, 2011 iv got a dt125 x 2007 and all its had done is the wire behind the clocks and a arrow exhaust and it will do 100 and everything else is totally standard 1 Link to comment Share on other sites More sharing options...
up.yours Posted October 3, 2011 Share Posted October 3, 2011 so,, . what you are saying, is all your 125's will piss all over my rd350lc , that will only reach 110mph, your all bonkers... Link to comment Share on other sites More sharing options...
up.yours Posted October 3, 2011 Share Posted October 3, 2011 why stop it there nev. Link to comment Share on other sites More sharing options...
NEV Posted October 3, 2011 Share Posted October 3, 2011 why stop it there nev. It'll get there Kev, you watch Titanium pistons, crank n barrel will be next Link to comment Share on other sites More sharing options...
up.yours Posted October 3, 2011 Share Posted October 3, 2011 Link to comment Share on other sites More sharing options...
NEV Posted October 3, 2011 Share Posted October 3, 2011 I'd call it Amy Winehouse syndrome, A dodgy needle Link to comment Share on other sites More sharing options...
Moderator mervin Posted October 4, 2011 Moderator Share Posted October 4, 2011 I do not doubt the man, you guys are thin king mph i am thinking kph then 100 = 62 mph merv Link to comment Share on other sites More sharing options...
NEV Posted October 4, 2011 Share Posted October 4, 2011 Nah Merv, 62 mph, thats the sort of speed you'd be getting from a tickled up DT50, a DT125, de-restricted at the speedo, with an aftermarket exhaust, would be somewhere between 75mph and 80mph, I'll be lucky if mine gets to 85mph, and mines effectively a 135, since I've had the overbore, plus all the extra whistles and bangs mines had done to it. The only way a DT125 is capable of doing 100mph, is in the back of an AA recovery van, and the drivers just been told his missus has gone into labour. Link to comment Share on other sites More sharing options...
Moderator mervin Posted October 4, 2011 Moderator Share Posted October 4, 2011 Nah Merv, 62 mph, thats the sort of speed you'd be getting from a tickled up DT50, a DT125, de-restricted at the speedo, with an aftermarket exhaust, would be somewhere between 75mph and 80mph, I'll be lucky if mine gets to 85mph, and mines effectively a 135, since I've had the overbore, plus all the extra whistles and bangs mines had done to it. The only way a DT125 is capable of doing 100mph, is in the back of an AA recovery van, and the drivers just been told his missus has gone into labour. Or Omar was seen going into his house with his cock out 1 Link to comment Share on other sites More sharing options...
Moderator DirtyDT Posted October 4, 2011 Moderator Share Posted October 4, 2011 Love the meter Nev. 1 Link to comment Share on other sites More sharing options...
up.yours Posted October 5, 2011 Share Posted October 5, 2011 oh it's all gone quite at the back, oh it's all ??????? Link to comment Share on other sites More sharing options...
AndyDtr08 Posted October 6, 2011 Share Posted October 6, 2011 What a hilarious thread! Link to comment Share on other sites More sharing options...
up.yours Posted October 6, 2011 Share Posted October 6, 2011 why does my 02 plate dt125 only do 70mph? why does my 82 plate rd350lc only do 110mph? Link to comment Share on other sites More sharing options...
