dt175 1988 fork oil capacity
naten
This post is 5410 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hey guys,
Just rebuild my bike and i want to flush the oil out of the shocks, just wondering if anyone knows how much fluid must go back in for a stock setup?
Also if anyone knows what the stock shock fluid weight is that would be helpful
thanks for any help
cheers
Hi Naten,
I am rebuilding a 1988 DT200r ( 1997 on logbook !! hey this is Cyprus ) and have found I have to search dt125 manuals for parts common to both . I have 1988 owners manual for dt200 and workshop manual for 1988 DT 125 on pdf if you want them - www.dtr125.net/workshop-manualf.htm.
If the forks are the same for 175 then you need 10w oil, 486cc , level 175mm from top of inner tube when fully compressed without spring
Hope this helps .
Regards Bob
