Guest Richmun Posted April 27, 2009 Share Posted April 27, 2009 Hi guys I put this in the wrong section last time. I have a 2001 model R1 that wants to go in to neutral between each gear, its not as bad when I am really getting up it but you cant always do that around town. I think it started doing around its last oil change. I used Motul 20W50, does anyone know if this oil would cause it if so what oil should I use. Thanks Richmun Link to comment Share on other sites More sharing options...
Madison Motorsport Posted April 27, 2009 Share Posted April 27, 2009 The oil should be fine, although I think 10/40W would be the ideal choice. If you are constantly popping into neutral, it would suggest to me that the clutch is not dis/engaging properly. This may be a simple clutch cable adjustment at the lever end. It could also mean a worn clutch. I would have a play with the adjuster first and see if it makes a difference. Link to comment Share on other sites More sharing options...
jimmythehat Posted April 30, 2009 Share Posted April 30, 2009 hi there, u need to use a 10 /40 weight oil, not 20/50. i have seen many gearbox faults on r 1s mostly down to wheelies and burnouts etc, oil wise go for castrol if you can, dont worry about going for a fully synthetic oil, they are waste of money,, check free play at clutch lever , you need to be able to pull back lever softly about 8/10 mm before feeling a resistance, this should leave you a gap of 3/4 mm at holder end of lever,can u change gears at fair speed with out clucth? does it still go in and out properly?? if you want more info call me ,, 07970918855. Link to comment Share on other sites More sharing options...
