Are there any other engines compatible with 90FZR1000 ?
fizzer1
This post is 5600 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I've heard the FZR1000 engine uses the same mounts as the FZR 750 and Fazer 700 which both have 6 speed transmissions. Not sure if the newer YFZ's are the same 5 valve Genesis engine or not. I've also read somewhere that you could take the FZR750 engine and use the FZR1000 cylinders and piston giving you a screaming 900 or so cc engine with the 6 speed, but not sure about all the little details/parts that are involved with that.
