xt 125 x derestriction
m3lon
This post is 5680 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
can any one tell me how to derestrict a 2005 xt 125 x, any help would be much appreciated
start at the air box is there a intake snorkel on the airbox if so remove it and make the hole that you see bigger and you could even drill holes in the top part above the air filter or even use a cone filter or a foam filter, also you could change the carb for a slightly bigger one and ream out the inlet manifold to the inlet manifold gasket and even the inlet port to the inlet manifold gasket, racing spark plug, performance exhaust, up the compression
cheers for the tips B)
