m3lon Posted September 20, 2008 Share Posted September 20, 2008 can any one tell me how to derestrict a 2005 xt 125 x, any help would be much appreciated Link to comment Share on other sites More sharing options...
racerd Posted September 22, 2008 Share Posted September 22, 2008 can any one tell me how to derestrict a 2005 xt 125 x, any help would be much appreciated start at the air box is there a intake snorkel on the airbox if so remove it and make the hole that you see bigger and you could even drill holes in the top part above the air filter or even use a cone filter or a foam filter, also you could change the carb for a slightly bigger one and ream out the inlet manifold to the inlet manifold gasket and even the inlet port to the inlet manifold gasket, racing spark plug, performance exhaust, up the compression Link to comment Share on other sites More sharing options...
m3lon Posted September 30, 2008 Author Share Posted September 30, 2008 start at the air box is there a intake snorkel on the airbox if so remove it and make the hole that you see bigger and you could even drill holes in the top part above the air filter or even use a cone filter or a foam filter, also you could change the carb for a slightly bigger one and ream out the inlet manifold to the inlet manifold gasket and even the inlet port to the inlet manifold gasket, racing spark plug, performance exhaust, up the compression cheers for the tips Link to comment Share on other sites More sharing options...
